My BooBoo from my last track outting.
Postby Andrew » Sun Oct 16, 2011 7:12 pm
I finally plugged up my cutout so I can hear whats going on. It sounds like front head noise to me but was curious what you guys thought before I started wrenching. Was hoping to get another stab at a PB before the track closed this year. Here is a vid of the noise.
http://s119.beta.photobucket.com/user/A ... 3.mp4.html
Re: My BooBoo from my last track outting.
Postby Swiggles » Sun Oct 16, 2011 7:30 pm
sounds top end to me, not as loud as when my rocker fell off from a broken rocker bolt but same kind of noise. bend pushrod maybe.
Postby Andrew » Sun Oct 16, 2011 7:34 pm
yes, bent rod or broken spring i think...
Postby deekster_caddy » Sun Oct 16, 2011 8:58 pm
I concur, a rocker-related problem.
deekster_caddy
Postby Andrew » Sun Oct 16, 2011 9:09 pm
Sweet. Say its a valvespring where can I pick just 1 up? Same with a push rod?
Postby deekster_caddy » Sun Oct 16, 2011 9:50 pm
Andrew wrote:Sweet. Say its a valvespring where can I pick just 1 up? Same with a push rod?
Keith probably has a few sitting around...
deekster_caddy
Postby americansoldier » Sun Oct 16, 2011 11:08 pm
lifter is my guess but bettter question is what has been upgraded as far as the valvetrain? how many miles on those specific parts? should be an easy fix once the valve cover is taken off
2003' GTP
Ported Blower
3.4 Pulley
1.95 Yella Terra Roller Rockers
LS6 Valve Springs/Pushrods
Powerlog/ 3" Downpipe/ Magnaflow Cat
Magnaflow Catback
K&N Intake
ESP Tune
UMI Trailing Arms
Nitto Drag Radials
13.8 @ 100 2.1 60 ft on Street tires
americansoldier
Postby murphinator » Mon Oct 17, 2011 10:36 am
stock stuff I have if you need it but in your sig " stage 3 heads & cam" so I am thinking you will be talking to intense....
2000 Z28 M6, 11.95 @111 street tires through the exhaust, QTP long tubes 3" duals , slp lid & intake, spano/koni/hotchkis susp. etc..
99 z28 long tubes , catback ,lid
1998 Z28 built A4 3600 stall , slp lid & lower , ls6 intake ,80mm tb, Kooks long tubes , 3" ss catback , 3.73's 12.1 @112 oct/2013 11's coming up spring 14
2002GS 1/4 mi 13.165 108.09 trap ,1/8 mi 8.562 , 84.87 trap on spray , 13.5 @104 without
GTP ON SPRAY 12.209 @117.75 1/8 MI 7.73 @94
murphinator
Postby Andrew » Mon Oct 17, 2011 10:53 am
Yeah. Stage 3 heads. Besides the block I can't think of anything thats "stock" on my car. Hopefully intense will sell a single of whatever I need if that is the case...
Postby Swiggles » Mon Oct 17, 2011 12:09 pm
i dont think they sell springs separately but you should be able to contact the manufacturer for a single if thats the problem.
Postby Andrew » Sat Oct 22, 2011 8:01 pm
Took 15 minutes and took the front cover off and checked rockers, springs and rods on that side of the engine and everything looked good... Hope I can find something under the rear cover...
Postby Swiggles » Sun Oct 23, 2011 1:39 am
my rocker fell off in the rear so hopefully something is there for you and its easy. if not then if suspect a lifter.
Postby Andrew » Sun Oct 23, 2011 6:27 am
Swiggles wrote:my rocker fell off in the rear so hopefully something is there for you and its easy. if not then if suspect a lifter.
yup, i do suspect a lifter...
it sounds identical to my truck when it had a collapsed lifter. but i didnt have as much knock on my truck (20+ degrees). im assuming the sound is whats making it do that?
Postby deekster_caddy » Mon Oct 24, 2011 9:38 am
Yes, the sound would make it log KR. Bummer.
Another thing that may help while you have the valve covers off - disconnect the injectors and have someone crank it over so you can watch the rockers move, that will give you a good clue if there is a problem. You can even run it briefly with the covers off but some oil may splash around.
deekster_caddy
Postby Andrew » Mon Oct 24, 2011 10:33 am
I will crank it over manually sometime soon. its looking like it wont get fixed before the weekend so i am no longer focusing on it. :(. i want to get my jeep out of my driveway before the snow falls.
Next
