No clue what whistling is coming from
Postby bellrockGTP » Thu Jun 21, 2012 10:52 pm
bellrockGTP
Re: No clue what whistling is coming from
Postby Swiggles » Fri Jun 22, 2012 7:45 am
Check all you vacuum lines, the rubber elbows and T's like to crack. Does the noise change when sc belt is on?
Postby Andrew » Fri Jun 22, 2012 9:47 am
is it constant or only when the engine warms up?
Postby bellrockGTP » Fri Jun 22, 2012 11:27 am
It is constant and no the noise is the same with or with out the sc belt on...looked over all the vacuum lines didn't see any issues...the noise countinued for about half a second right when you shut the engine off
bellrockGTP
Postby gtped » Fri Jun 22, 2012 11:32 am
Check your exh manifolds if there is a crack it will whistle
2000 GTP 201k (SOLD)
2004 Accord LX (wife's)
2004 Seabring Conv.(SOLD)
2004 LESABRE(SOLD)
2011 Kia Sx 5 dr
Ed
http://www.cardomain.com/ride/847103
gtped
