Dash lights partially out.
Postby TrevorGTP » Sat Jun 23, 2012 9:27 pm
the subjects says it all. Is it a bulb that needs to be replaced? or do I need a whole new dash. I'm guessing a bulb but was wondering if anyone ran into this.
Tuned, 3.4 MPS, SD heatwrapped headers, ZZP stainless cat back 2.5, 3 inch downpipe catted, F- Body brake kit Cross Drilled and Slotted rotors, 160 T stat, 104's, Prosport Boost Gauge and Aeroforce.
TrevorGTP
Registered
Re: Dash lights partially out.
Postby Andrew » Sat Jun 23, 2012 9:42 pm
Your dash board consists of like 20 bulbs... where exactly?
12.100 @ 109.31
Stage 3 heads & Cam, TOG Headers, S2 Inter-cooled, GenV Blower, N* Throttle Body, 60lb Injectors
Andrew
Site Admin
Postby TrevorGTP » Sat Jun 23, 2012 10:08 pm
The whole coolant temp thing is black and a little bit of the speedo like from 115 to 95
TrevorGTP
Registered
Postby TrevorGTP » Sun Jun 24, 2012 1:28 am
fixed..
TrevorGTP
Registered
Postby Kevin » Sun Jun 24, 2012 10:34 am
they ussually charge ridiculous for those little bulbs to
04 Ion redline
3" Catless downpipe,zzp tune,3.0 mps
Kevin
Registered
Postby Justin Dalio GTP » Mon Jul 09, 2012 12:31 am
Or you can get a pocket full of them at a junkyard for $2. :wink:
13.732 @ 101.74mph
Old: 2001 Pontiac Grand Prix GTP
New: 2011 Infiniti G37x
Justin Dalio GTP
Registered
Postby Swiggles » Mon Jul 09, 2012 12:38 am
The ones for the speedo are plain 194 bulbs in the blue holders. The ones for the dic are the ones perminitly in the plastic holders.
Swiggles
Registered
Postby Supercharged03GTP » Mon Sep 24, 2012 12:24 pm
I have a some what's similar problem... Only difference is the gas gauge and half of the rpm gauge work sometimes but then goes out on its own.. When I first start the car for the da and turn on the lights all the lights on the gauges will work, then after driving for approx 5 minutes only half of it works... It's def not a bulb issue, so what else could it be if its intermittent?
2003 Pontiac Grand Prix GTP Limited Edition (Stock) for now
Supercharged03GTP
Registered
Postby Supercharged03GTP » Mon Sep 24, 2012 12:36 pm
I just did a little research and I came up with a potential solution... Going to attempt this later but I'm thinking I should pull the gauge cluster out and look at the soldering joints and see if they need to be resolded if that's the case it should fix it... Anyone else experience this issue in there Grand Prix before?
Supercharged03GTP
Registered
Postby Supercharged03GTP » Thu Oct 18, 2012 11:29 pm
So I took the gauge cluster out and looked at the soder joints and it all checked out fine... so what else could it be? it works intermittently... it sounds like a short.. If it is, I hate tracing them... where do I begin... please help.. thank you.
Supercharged03GTP
Registered
Postby Supercharged03GTP » Tue Dec 04, 2012 8:08 am
bump... its an intermittent problem.. but most of the time it just doesnt work on the side of the fuel gauge and half of the tach, but once in awhile it does work.. i really want to get this working properly again.. can anyone help? Thanks again guys :)
Supercharged03GTP
Registered
Postby deekster_caddy » Tue Dec 04, 2012 1:13 pm
Sounds like a bad solder joint. You can't always tell by sight. Did you resolder them or just look at them?
'98 Buick Riviera; Gen V 3.2 pulley, N*, VS Cam, 180 stat, Custom PCM (Powrtuner), headers & HF cat , 42.5 lb inj.
Grant-built/PRJ/Thrasher trans 3.29 gears, 7/8 chain, zzp hardened IS
13.8@101 ET
deekster_caddy
Registered
Postby Supercharged03GTP » Tue Dec 04, 2012 1:37 pm
I just looked at them, but none of them appears to be bad.. I'm stumped.
Supercharged03GTP
Registered
Postby TrevorGTP » Fri Dec 14, 2012 7:22 pm
I know you said it wasn't a bulb issue but did you replace it? If you haven't try that usually its the bulb but not sure.
TrevorGTP
Registered
Return to Grand Prix
Who is online
Users browsing this forum: No registered users and 1 guest
cron
