Going turbo
Going turbo
Postby Swiggles » Sun Aug 05, 2012 10:08 am
Well as some of you may know I'm going turbo :D . I was able to trader for most of the parts and will end making a little money when sell the rest. I pieced it together rather quickly, and u have just about everything for the install ready to go. Jason is polishing my l26 intake, and yesturday he drop off my 91k l36 from an fbody. I will end up using the fbody intake sometime next year, I just don't have the money for it this time. More will be added as things get put together. Turbo, cam, and tb will be here tomorrow. Motor might end up get an l36 uim while I wait for the l26 polishing to be finished.
So the motor will be:
- L36 with a polished l26 uim
- hv3 insert
- stage 3 zzp l67 heads with 130# springs
- comp cam 1.7 roller rockers
- Stattama stage 2 cam
- double rollmaster
- ls7 lifters
- comp cam stock size pushrods
- Mls head gaskets .056
- Z7 turbo pipes with intercooler
- 256s Bog Warner turbo with .70 ar
- 3" tog downpipe with cutout
- 3" resonator pipe to borla exhaust at the Y
- Tial bov
- Tial wastegate 38mm
- ported l67 tb with fixed AFC
- dual valve catch can
Re: Going turbo
Postby Swiggles » Mon Aug 06, 2012 8:08 pm
Turbo and cam arrived today.
Re: Going turbo
Postby murphinator » Mon Aug 06, 2012 8:47 pm
sounds like a fun ride Brian - cant wait to see how it works out for you.
2000 Z28 M6, 11.95 @111 street tires through the exhaust, QTP long tubes 3" duals , slp lid & intake, spano/koni/hotchkis susp. etc..
99 z28 long tubes , catback ,lid
1998 Z28 built A4 3600 stall , slp lid & lower , ls6 intake ,80mm tb, Kooks long tubes , 3" ss catback , 3.73's 12.1 @112 oct/2013 11's coming up spring 14
2002GS 1/4 mi 13.165 108.09 trap ,1/8 mi 8.562 , 84.87 trap on spray , 13.5 @104 without
GTP ON SPRAY 12.209 @117.75 1/8 MI 7.73 @94
murphinator
Re: Going turbo
Postby sleeperZ96BT » Tue Aug 07, 2012 9:40 am
WTF is a stamman cam?
1993 Formula track car M6
1996 Impala SS A4 soon to become M6
1997 Camaro SS M6
sleeperZ96BT
Re: Going turbo
Postby Swiggles » Tue Aug 07, 2012 1:47 pm
Stattama sorry lol
Re: Going turbo
Postby deekster_caddy » Tue Aug 07, 2012 8:05 pm
Is that still my old L67 you are running now?
Anything wrong with it?
deekster_caddy
Re: Going turbo
Postby Swiggles » Tue Aug 07, 2012 10:28 pm
No Derek I blew that motor up. Popped 3 pistons on it because my rocker geometry was off and I had way too much lift. I got about 50k out of it though and it was still running strong until then.
I'll be using a 91k fbody l36 for this build
Re: Going turbo
Postby Wotgtp » Tue Aug 07, 2012 10:47 pm
Good to hear everything is working out Brian! I'm looking forward to see what you end up making for power.
-Ed- 2000 Daytona GTP
Cross drilled/slotted rotors with hawk pads and Impala front calipers, 3.1 SC pulley, Gen V, NIC, AEM WB, SLP Headers w/cat, AL104's, ZZP intake, ZZP 10.4 wires, 180*T-stat, Tim king trans, KYB GR-2/Vogtlands, GMPP sways and poly bushings, BMR TA's
Wotgtp
Re: Going turbo
Postby Swiggles » Wed Aug 29, 2012 7:29 pm
Heres my big update. Progress has been really slow, work picked up for a few weeks and i had to send out all of exhaust stuff to zzp for them to make my custom 3" upper turbo downpipe. They ran into a few snags and had fix and change my cross over around. But I'm glad I went with them because things would not have fit right when went to install if they hadnt got the parts for the downpipe. Those parts will all be here tomorrow, some other misc stuff will be here beginning of next week, and I still have to meet up with Max for the torque converter before I can put the motor back in.
I decided to go with 1.6 roller rockers since Max was selling the set i wanted and i already had someone who wanted the 1.7s so I didn't have to pay anything for them.
Just about everything on the car will AN lines, man those add up quick :roll: . but it will be worth it once its all put together.
Polishing on the UIM looks great so far but i still need to get it soda blaster which i should have done from the start and saved Jason's arms and sanity.
So on to some picks...
What came out, traded the GenV and TOGs for the turbo and ST2 cam.
Putting this block in, 91K from a '97 Camaro. I will probably be selling the intake.
Cleaning the block didnt take much. Jason did all the work so it was a breeze for me :lol: .
You can even see the arrow on the pistons, damn this motor was clean.
Got the 1.6 rockers in the mail today, second time I've bought them from Max lol.
To top off the heads.
AN fittings on the back of the UIM for the vacuum block feed.
OOO shiny. The L67 adapter is on upside down so i can use the stock l26 EVAP location. I'm hoping this will work.
Ported L67 TB.
Got some nice bolts for the sensors.
OOO shiny turbo
And to protect it all and let that extra heat out. Thanks Jason's dad!! Its painted now, but I'm waiting till it goes on for those pics.
As she sleeps at the moment.
Re: Going turbo
Postby reveregtp » Thu Aug 30, 2012 12:03 pm
nice progress! keep it up
reveregtp
Re: Going turbo
Postby Andrew » Sun Sep 02, 2012 9:23 pm
i like the red and black valve covers. how did you do them so well?
Re: Going turbo
Postby Swiggles » Wed Sep 05, 2012 7:13 pm
they are 06+ l32 valve covers that come in black stock, then i got the valve cover overlays from reflective concepts and only used the center ones.
Re: Going turbo
Postby Andrew » Thu Sep 06, 2012 3:52 pm
oh ok...
wanna part with them? i see you have the aluminum covers there.
Re: Going turbo
Postby Swiggles » Thu Sep 06, 2012 6:14 pm
ive been thinking about it, not sure if i want to let them go just yet though. if do youll be the first to know.
motor is back in now, still more to hook up, hopefully will just about done tomorrow but theres so many little things...
been updating pics on gpf, dont feel like doing twice so heres the thread if you feel like following it.
http://www.grandprixforums.net/swiggles ... 67700.html
Re: Going turbo
Postby bud659 » Wed Oct 10, 2012 6:16 pm
looks awesome Brian.
2004 CompG headers, pulley, plugs, cai, RTA's, custom pcm
1998 Pontiac GrandPrix GTP rockers, headers, pulley, plugs, custom pcm, GMPP handling Kit
1988 Chevrolet Monte Carlo SS 350 GM Crate Motor, Alum Intake, Jet-Hot Hooker Headers, Hypertech chip, MSD 8.5 Ign Wires, Accel Ign Module,Cap+Rotor, Dynomax cat-back 2.5" exhaust, 3:73 Gears, 200-r4 tranny street/strip build
bud659
