headers vs zap power log
Postby ktraygtp » Thu Dec 27, 2012 1:23 pm
need some help what is a better thanks for the buck ZAp powerlog setup or headers
01 gtp intake 3.4 pulley free flow exhaust zzp pcm 104 plugs
ktraygtp
Newbie
Re: headers vs zap power log
Postby ktraygtp » Thu Dec 27, 2012 1:37 pm
Bang for the buck damn spell check
ktraygtp
Newbie
Postby Andrew » Thu Dec 27, 2012 1:40 pm
You can edit your posts.
Headers.
Postby murphinator » Thu Dec 27, 2012 9:28 pm
you list a 3.4 pulley in your sig without either currently
headers support a 3.4 better than a plog
a 3.4 on stock manifolds especially in cold air will chip the ring lands on #3 cylinder (front middle) , your on borrowed time on that small of a pulley without supporting mods
2000 Z28 M6, 11.95 @111 street tires through the exhaust, QTP long tubes 3" duals , slp lid & intake, spano/koni/hotchkis susp. etc..
99 z28 long tubes , catback ,lid
1998 Z28 built A4 3600 stall , slp lid & lower , ls6 intake ,80mm tb, Kooks long tubes , 3" ss catback , 3.73's 12.1 @112 oct/2013 11's coming up spring 14
2002GS 1/4 mi 13.165 108.09 trap ,1/8 mi 8.562 , 84.87 trap on spray , 13.5 @104 without
GTP ON SPRAY 12.209 @117.75 1/8 MI 7.73 @94
murphinator
Postby Andrew » Thu Dec 27, 2012 9:35 pm
whats a ZAp
Postby murphinator » Thu Dec 27, 2012 10:18 pm
I assume he meant zzp not zap since zzp are the only ones making a powerlog
murphinator
Postby Andrew » Thu Dec 27, 2012 10:41 pm
i figured... but he typed it twice so i dont think it was a typo.
Postby Swiggles » Fri Dec 28, 2012 8:57 am
go with the speed daddy or ssac/ssax they are the same company on ebay. they are $200 slp knock off headers, youll want to get a new 3" flex pipe from zzp and new 2 1/4 band exhaust clamps for them though. on once thats done get rid of that zzp pcm and get a real tune.
Postby ktraygtp » Fri Jan 04, 2013 10:30 am
Yea sorry ment zzp are the knock off headers any good thou for like longevity and not cracking at the welds like most knock offs
ktraygtp
Newbie
Postby deekster_caddy » Fri Jan 04, 2013 10:45 am
I've had a set of the SSAC on my car for many many years now with no cracking or issues.
deekster_caddy
Postby murphinator » Fri Jan 04, 2013 7:24 pm
funny you bring up cracking at the welds , that is a known issue with zzp powerlogs , I had a mild steel that cracked , replaced it with a stainless that has held up well on one of my L67 cars
murphinator
Postby Swiggles » Tue Jan 08, 2013 11:22 am
my used front plog for my turbo had cracks. supposedly the new plogs are welded better and wont crack. either way if the plog cracks you can send it back to zzp and they will fix it.
i havent head of any issues with the welds on the speed daddys
Postby murphinator » Tue Jan 08, 2013 9:32 pm
Swiggles wrote: either way if the plog cracks you can send it back to zzp and they will fix it.
only until 1 year from purchase date , mine was 13 months so no dice , they did offer to do it at a reduced cost but when added to shipping both ways it was cheaper to have it done locally
murphinator
