Possibly head gasket repair
Re: Possibly head gasket repair
Postby deekster_caddy » Thu Jan 24, 2013 1:01 pm
I don't recall removing the valve covers to do the LIM gaskets. Unless your VC are leaking and you want to replace them, I don't think you have to pull the valve covers.
'98 Buick Riviera; Gen V 3.2 pulley, N*, VS Cam, 180 stat, Custom PCM (Powrtuner), headers & HF cat , 42.5 lb inj.
Grant-built/PRJ/Thrasher trans 3.29 gears, 7/8 chain, zzp hardened IS
13.8@101 ET
deekster_caddy
Registered
Postby ignorant prodigy » Wed Jan 30, 2013 10:51 am
I think Greg meant maybe the TB gasket is leaking.. causing the coolant to mix with your air/fuel.
are you puffin white smoke even when the car's warm?
00 Buick Regal GS
88 fiero L67 swap in progress
ignorant prodigy
Registered
Postby Snaoum » Wed Jan 30, 2013 3:41 pm
I have noticed there to be a decent amount of white smoke. I did not order a TB gasket, I am running gen3 SC with N* TB. Didnt even think of that. Will just tap and block LIM coolant holes.
S1X cam-S&S headers-S3 SC- ported LIM-3.6/3.4/3.25 mps-CAI-180 t-stat-N*-GMPP handling kit-12"brakes-SLP GTX hood-SLP gen1 spoiler-Tune.
Snaoum
Registered
Postby murphinator » Wed Jan 30, 2013 9:26 pm
when I thought my lim gaskets took a dump Ibought the alum gaskets , sc gasket , tb gasket , rtv ,teflon pipe thread sealant etc... pulled off the sc/tb and then noticed coolant on the rotors....
wrong direction for lim gasket leak lol but I allready had the thing half apart so I did the LIM job , it had blown a tb gasket even though I had borrowed an inch pound torque wrench and torqued the tb down to spec , in my case i blame my stupidity in buying a zzp tb spacer as many people end up blowing tb gaskets after installing one my point is a tb gasket wil raise havoc , smoke white etc... maybe pull the tb and shine a light in on the rotors to see if they have coolant on them ???
2000 Z28 M6, 11.95 @111 street tires through the exhaust, QTP long tubes 3" duals , slp lid & intake, spano/koni/hotchkis susp. etc..
99 z28 long tubes , catback ,lid
1998 Z28 built A4 3600 stall , slp lid & lower , ls6 intake ,80mm tb, Kooks long tubes , 3" ss catback , 3.73's 12.1 @112 oct/2013 11's coming up spring 14
2002GS 1/4 mi 13.165 108.09 trap ,1/8 mi 8.562 , 84.87 trap on spray , 13.5 @104 without
GTP ON SPRAY 12.209 @117.75 1/8 MI 7.73 @94
murphinator
Registered
Postby Swiggles » Thu Jan 31, 2013 1:43 pm
ya murph i would blame your problem on the tb spacer. were gunna do his lim gaskets and im gunna plug his coolant holes while its off.
Swiggles
Registered
Postby murphinator » Thu Jan 31, 2013 7:18 pm
Swiggles wrote:ya murph i would blame your problem on the tb spacer. were gunna do his lim gaskets and im gunna plug his coolant holes while its off.
yes I did not re-install it , just saying a leak at the tb gasket is worth looking at
murphinator
Registered
Postby Swiggles » Sun Feb 03, 2013 5:48 pm
Sam came over yesterday and we got the lim gaskets done. The top his motor was filthy lol. he did have the plastic gaskets and they failed again. we replaced them with the metal ones, there wasnt much coolant getting into the motor, most of it was just puddling in the back of the lim. I also plugged the coolant holes in the lim and opened up the passage to the rear head. Hes back up and running now and the top is nice and clean now. :D
Swiggles
Registered
Postby Snaoum » Mon Feb 04, 2013 8:53 am
Thank you Brian for helping me out with the LIM gaskets. Yes the engine bay was filthy, but its the filth that keeps it from leaking shit all over. As of this morning everything still running fine and I bet she is still clean under the hood.
Snaoum
Registered
Previous
Return to Grand Prix
Who is online
Users browsing this forum: No registered users and 1 guest
cron
