Belt Sizes
Belt Sizes
Postby Andrew » Mon May 19, 2008 4:37 pm
Stolen form ClubGP
Part Number Examples
Napa/Gates: 060XXX
Goodyear: 4060XXX
Dayco: 5060XXX
Duralast: XXXK6
No IC
Grand Prix
3.8 (Stock): 665
3.2-3.5: 660
2.85-3.1: 650
2.7-2.85: 642
Bonneville
Stock: 721
3.4: 716
With ZZP Stage 2 IC (2.25” tall Core)
6 Rib
3.3-3.8: 685
2.7-3.2: 680 (Note that the NAPA 680 may be too long for 2.8" and smaller. Try a NAPA 672)
2.5-2.6: 672
8 Rib NOTE: For these belts the part numbers are 080 rather than 060...or K8 with the Duralast rather than K6.
3.0-3.2: 685
2.6-2.9: 680
Gen 5 Blower
2.9-3.1: 685
2.7-3.0: 680
2.4-2.6: 675
With ZZP Stage 3 IC (??? tall Core)
6 Rib:
3.1-3.8: 685
2.6-3.0: 680
Gen 5 Blower
3.0-3.8: 685
2.6-2.9: 680
2.3-2.55: 675
Gen 5 Blower with ATI 10% overdrive balancer
2.8: 695
With ZZP SSIC (1” tall Core)
3.2-3.8: 670
3.0-3.1: 667 (Stock belt)
2.8: 660
With MAP IC (2.0” tall Core)
3.1-3.4: 680
2.8-3.0: 672
With WBS IC (1.91” tall Core)
No information currently. MAP IC belt reference would be close but the belts listed there will be a bit long for some applications with the WBS IC.
With Thrasher IC (2.5” tall Core)
2.8: 672
3.0: 680
ZZP SS M90 Conversion
k060970 - SS M90 for 97/98
K060950 - SS M90 for 99+
Other Belts
060915 - Stock accessory belt for 99-03
-also works with either UD WP pulley or OD alt pulley but not both.
060905 - Stock Accessory belt for 04+
060923 - Accessory belt for 99+ with UD WP pulley and alt UD pulley.
4060935 - Stock accessory belt for 97/98 (94").
4060938 - Accessory belt for 97/98 with underdrive pulleys.
Metal Pulley Diagram:
12.100 @ 109.31
Stage 3 heads & Cam, TOG Headers, S2 Inter-cooled, GenV Blower, N* Throttle Body, 60lb Injectors
Andrew
Site Admin
Postby crab daddy » Mon May 19, 2008 4:55 pm
I ran a 675 with a 2.8 pulley and a 670 with the 2.6 (zzp s2 ic)
I found it to be too sloppy with the bigger belts that were suggested. They worked fine when you first put them on but once you run them a little they seem to stretch out.
I run my belts tight as fuck though. which is how I got away with a 6 rib setup and no slip issues with a 2.6 pulley.
12.466 @ 114.15 INTENSE S1X/ZZP IC/TOG HeadersImage
2006 Nissan Titan 4x4/ 2011 Nissan Altima coupe
1972 Harley Davidson XLCH 1000 Sportster
crab daddy
Registered
Postby John » Wed May 21, 2008 1:10 pm
Where would an Intense IC sit in there?
John
Site Admin
Postby deekster_caddy » Wed May 21, 2008 2:33 pm
Should be the same as any other core of the same thickness. How thick is the IC?
'98 Buick Riviera; Gen V 3.2 pulley, N*, VS Cam, 180 stat, Custom PCM (Powrtuner), headers & HF cat , 42.5 lb inj.
Grant-built/PRJ/Thrasher trans 3.29 gears, 7/8 chain, zzp hardened IS
13.8@101 ET
deekster_caddy
Registered
Postby crab daddy » Wed May 21, 2008 2:47 pm
M90 with 1.91" thick intercooler - W-body:
GB6-680 - 6-rib, 2.90" - 3.00"
GB6-672 - 6-rib, 2.60" - 2.80"
GB8-680 - 8-rib, 2.90" - 3.00" (+$14.00)
GB8-675 - 8-rib, 2.60" - 2.80" (+$14.00)
M90 with 1.91" thick intercooler - G or H-body:
GB6-710 - 6-rib, 2.60" - 2.80"
wbody and intense have the same size core
crab daddy
Registered
Postby BillBoost37 » Sun Oct 12, 2008 7:44 pm
Homies..can we please update el sizes..
Bonne
Gen 3 or Gen 5
Stock
720
3.4-3.2
715
WBS 2" IC
3.0
725
Swiggles wrote:pics slow down the build process ....
97 B'ville SSEi Gen V, S1X, 1.8RR's, N*, 3.29's w/LSD, .592" of lift happiness
BillBoost37
Registered
Postby Swiggles » Wed Aug 12, 2009 11:17 am
Stage2 IC with larger idler pulley and 3.8 SC pulley - 705
Swiggles
Registered
Postby hitman92499 » Sun Apr 10, 2011 2:36 pm
Swiggles: stage 2 IC, 3.8 pulley, Gen 5, Bonneville brackets, 8 rib = 080735 belt
hitman92499
Registered
Postby Swiggles » Sun Apr 10, 2011 4:30 pm
no thats on the 3.4 pulley. and its a 2 5/8" IC which is about a 1/4 in bigger than the stage 2 :D
Swiggles
Registered
Return to Grand Prix
Who is online
Users browsing this forum: No registered users and 1 guest
cron
