Is This Possable
Is This Possable
Postby supercharged_gt » Thu Sep 13, 2012 7:34 pm
I was making a del. today to porter and chester, A indt. there told me about a new machine shop that built a 3800 for a grand nath. regal,I Was told togothere, he saidi wont beleive it,1800 h power,dont have any info on the build as of yet,what do you guys think?
Re: Is This Possable
Postby Andrew » Thu Sep 13, 2012 7:51 pm
wut? :?
Postby Swiggles » Fri Sep 14, 2012 8:39 am
Yes that's possible but it's a different 3800 that doesn't work with our cars
Postby deekster_caddy » Sat Sep 15, 2012 10:00 pm
80's GN and Regal used the old RWD standard 3.8, not the new series FWD metric 3800. Different everything, same idea.
It's easy to make a ton of power w 3800 but hard to get it to the ground. You will spend a fortune in transmissions and axles etc when you make a fast FWD. RWD is much more durable - straight back with a straight durable transmission and basic rear axle is very easy to put power through reliably. FWD not so much.
Postby Specter GXP » Sun Sep 16, 2012 2:43 pm
I have never seen an 1800 HP GM but I know 12 is possible.. :!:
2007 Grand Prix GXP
Specter GXP
Return to General
