Impala from MA
Introduce yourself here.
Impala from MA
Postby k6ng6r00 » Sat May 12, 2012 10:00 pm
Basically a pontiac... I go to umass lowell this is my car...
2004 3400 - CAI, zzp 2.5in dp, 06 ss 2.5in catback, overkill pcm, SSC springs on AGX struts, GMPP Handling Kit, Kenwood/Focal/Infinity/Polk Sound System
k6ng6r00
Re: Impala from MA
Postby The Godfather » Tue May 15, 2012 10:24 am
Nice ride guy. I thought it was an L67 at first but looked at your page and saw it's only a 3.4. Didn't know there was a vortech kit for it!
What HP gains do people get from those?
The Godfather
Re: Impala from MA
Postby k6ng6r00 » Tue May 15, 2012 10:39 am
There isnt one... its custom fab from rsm. They make 80 suposedly on the grand ams!
k6ng6r00
Re: Impala from MA
Postby Swiggles » Tue May 15, 2012 11:50 am
Looks like a fun project if you can do the fab work yourself. If not you'd be better off doing and l67/l32 swap, it would be much easier and cheaper.
Re: Impala from MA
Postby k6ng6r00 » Tue May 15, 2012 11:54 am
The fab work is already done, the only fabbing i need to do is cobble together some rubber couplers for the plumbing once i get it bolted in
k6ng6r00
Re: Impala from MA
Postby Swiggles » Tue May 15, 2012 12:19 pm
well what are waiting you for couplers are cheap enough :D
Re: Impala from MA
Postby k6ng6r00 » Tue May 15, 2012 12:34 pm
Wideband isnt in yet, oil pan needs to be tapped. Got a welder?
k6ng6r00
Re: Impala from MA
Postby Swiggles » Tue May 15, 2012 12:47 pm
i do not :? some day i will.
cant you add a T to the oil pressure sending unit for the oil instead of tapping the pan. thats what zzp does for the turbo kit isnt it?
Re: Impala from MA
Postby k6ng6r00 » Tue May 15, 2012 12:53 pm
You can use that for the feed and i need hardware also, but the oil has to be dumped back into the engine through the pan, above the oil level, with a hose going as vertical as possible to help gravity... Need to write up a shopping list for the hardware store... i need like 10 bolts 2 fittings 2 hoses a couple couplers and a bunch of clamps...
k6ng6r00
Re: Impala from MA
Postby Swiggles » Tue May 15, 2012 1:49 pm
that could be done with out welding, and they make kits.
http://www.summitracing.com/search/?key ... 0kit&dds=1
Re: Impala from MA
Postby k6ng6r00 » Tue May 15, 2012 3:46 pm
It can be tapped but i still need a bung welded for the wideband... and if im doing that i might as well have someone weld the a nice bung to pan... one less set of threads to leak.
k6ng6r00
Re: Impala from MA
Postby Swiggles » Tue May 15, 2012 5:35 pm
thats an easy one for an exhaust shop to do on the car. but depending on which WB you have you simulate the narrowband with and it will run the wideband as both. I'm doing it with my LC-1 right now. i know the plx will do it too, not sure about the AEM ones though.
Re: Impala from MA
Postby ShaggyK » Tue May 15, 2012 9:03 pm
oh hai
Looks like a nice car you got there, bet you can't wait to get that vortech on.
and having gone to UML, I feel sorry for you having to park in that parking lot.
04 SS Supercharged
ShaggyK
Re: Impala from MA
Postby k6ng6r00 » Tue May 15, 2012 9:22 pm
Yeah fuck lowell haha i have been hit twice in the last six months by idiots who cant park without leaving a trail of wreckage.... and the door dings... luckily ive only had one bad one so far.
k6ng6r00
Re: Impala from MA
Postby Andrew » Tue May 15, 2012 9:46 pm
Welcome! I work for Trinity in Lowell... I'll keep an eye out for your ride when I am out there.
Next
Return to Introductions
